Reactions during refinishing porjects
7/25/24
Roy R H Member
Hi there,
so we've taken on a couple clients that retail refinished mid century furniture in the cities, a mix of stuff made in the U.S. and France (sometimes Italy too).
Most of the time I'm able to seal coat anything after any repairs and touch ups with Milesi's self seal acrylics with out any issues, but every once in a while i run into slippage reaction. It is generally occuring on larger flat surfaces such as table tops or show piece doors (burl wood veneer, etc), but almost never on edges, back and underside, and never on legs and other structural uprights.
My guess is over the centuries of previous ownerships some pieces had been kept up with various different polishing waxes. Milesis/Ilva's barrier coat tend not to be able to handle these kind of reactions and I find myself resorting to shellac sealer (dewaxed) before moving on to the according topcoats (usually Milesi's lower sheen Acrylics).
1. Im looking for recommendations on industrial wood coatings degreasers/dewaxers that can eliminate this without messing with any of the previous finishes/stains/glazes etc.
2. Are there any universal sealers other than shellac that folk can recommend?
On second thought im also wondering about the high humdity in the shop this time of year, and if that would cuase slippage reactions when using acrylic solvent coatings?
thank you for any input, suggestions, corrections and advice!
Roy
7/28/24       #3: Reactions during refinishing porjec ...
Frank Garrido  Member
Website: http://www.cabinethero.com
Best thing I do when working with older furniture pieces is definitely , do a thorough de waxing using V&P Naptha . This really dissolves the wax quickly , it’s important to quickly soak up the wax with a clean cloth . Do this a few times to make sure the top and sides are cleaned thoroughly . Mineral spirits can work good as well .
As far as another coating to use as a barrier other than Shellac for vintage furniture pieces I would have too say , it’s a proven reliable traditional coating which a lot of vintage pieces are finished with either Shellac
Or Lacquer . So there is not much risk when using these type of coatings on older vintage furniture pieces .
7/29/24       #4: Reactions during refinishing porjec ...
Matt Calnen
I second what Frank said. I have not seen to many products out there that say don’t have se anything but “their” product. Understand what’s on the surface and work with it.
8/1/24       #5: Reactions during refinishing porjec ...
BH Davis  Member
I agree with all said above. I'll only add the obvious that it's a good idea to test your dewaxer on a hidden area first.
