Smeared finish
8/1/24
Marcus
Hi guys. I use ChemCraft Chem 24 Cv. I have a job sprayed in that product, SW Iron Ore color. The customer is complaining about "smearing or streaking" and fingerprints showing when she wipes the finish. Have you had a situation like that, and could it just be the dark color?
8/1/24       #2: Smeared finish ...
Tell her to use a different cleaning product and see if things change.
8/4/24       #3: Smeared finish ...
FM
This is a common problem with dark colors using clear bases. Anything and everything will show. I personally can’t sell anything above a 10 sheen in this or similar colors and have shot it in 4 different finishes including chem24. It will also slow down true dry times- time before printing and stacking and damage will not occur.
8/4/24       #4: Smeared finish ...
shenendoah
clear top coat as final coating
8/7/24       #5: Smeared finish ...
Frank Garrido  Member
Website: http://www.cabinethero.com
Try switching to another type of
CV I have found some brands are better with darker pigments,but one thing to consider is not thinner your coating to much or this will definately affect the quality of the coating. Some brands formulate their varnish pretty consistent and really do not require thinning
therefore the color pigments are more likely to be locked in the solids. Thus the catalyzed coating would be not so susceptible to sheen changes when rubbed I switched to Mohawk CV and found it to work well for me. If you try another brand and perform a test you can validate the switch over.
