Wood filler 'ghosting' through stain.
9/4/24
David
Hi
We have just recently started having this issue on stain grade (A=1) Maple plywood. As you can see from the photo (Upper portion), where the wood putty is applied, even after sanding, it is leaving some type of residue or film that is blocking the stain from being absorbed. The filled holes seem to be absorbing the stain. Just the 'ghost' of where the original putty was applied. We are definitely sanding enough. We are trying to resolve this issue but are not having any success. We use Timbermate wood putty. We outsource our finishing to a full time finish house and they use commercial grade finishes. My only thought is perhaps the container of Timbermate has some type of contamination (oil perhaps) that can't be sanded away. This does seem to have begun after we got the most recent tub of Timbermate. Any thoughts would be appreciated. Thanks in advance.
View higher quality, full size image (1512 X 2016)
9/7/24       #3: Wood filler 'ghosting' through stai ...
Chemmy
Would like to help, but can't understand why you would be trying to fill the grain on Maple to begin with..!! If for some reason I was inclined to do so, I would use a clear spray filler, slightly tinted, to do so, allowing me to easily see that all of the surface sealer was removed completely..!! But I will leave that up to you as an option.!!
9/7/24       #4: Wood filler 'ghosting' through stai ...
David
So the photo doesn't really convey this but there is a miter joint on both edges that we needed to use pinch clamps to pull together so the putty was for the holes that the pinch clamps left. I will explore your suggestion.
9/16/24       #5: Wood filler 'ghosting' through stai ...
Mr Fee Member
we get that on stain grade when the guys apply too much putty and don't sand enough.
10/7/24       #6: Wood filler 'ghosting' through stai ...
I had that happen with timbermate when the guy left too much on for about a month. It left that halo mark. Very hard to sand off. It was on baltic pine.
3/9/25       #7: Wood filler 'ghosting' through stai ...
Bj Neumann
Website: http://neumanncompany.com
We do high end luxury finishing on our cabinets. We find it best practice on stained wood to never use filler before stain & seal. After seal then we can fill holes & blemishes with a soft touch up crayon by Mohawk. This way we can color match each individual hole/blemish. If you use a generic wood filler before stain, you will always end up with a mixed bag of nuts. Hope this helps, but there are certain fills you need do pre-stain & others post seal, prior to final.
