2k question
9/18/24
dar
going to use 2k on a residential bar top, probably sirca, 1st question they have a 2k poly and a 2k acrylic poly what is difference? Also they have an isolater and a sealer, going over mohawk fast dry oil stain should I use isolater and sealer or just one or the other? thanks
9/18/24       #2: 2k question ...
Chris
2k acrylic urethane is non yellowing. We use Ilva products .
We use sealer over our stains.
9/19/24       #3: 2k question ...
mauricio poli
Very important to check with Sirca a complete finishing schedule, using only Sirca products.
One never know what will happens using different brands in a finishing.
If it is necessary to use the Mohawk stain, then you should apply isolator over the dry stain, after all the coats you need to close the pores, and finally the top coat.
In case of a light color, you can use PU acrylic system
If not, use the PU system.
