conversion varnish looks slightly milky when applied in cooler weather.
11/18/24
stoneaxe Member
Our finishing is done by a independent finish shop. It is conversion varnish. The shop has a large rollup door, often partially open. I would call the climate in the shop "semi" controlled. This is in the Pacific Northwest- high outside humidity in the winter. In the fall, I have started to notice a slightly milky look to the finish, and occasional hazy white spots here and there. Is this a temperature-humidity problem? Is there anything else that could cause it?
11/18/24       #2: conversion varnish looks slightly m ...
FM
It’s blush. Too much humidity trapped under the finish.
12/3/24       #3: conversion varnish looks slightly m ...
Professor Finishing
There are several variables that can cause this effect.
A) check the bottom of the pail make sure no settlement of flatten paste.
B) no air movement flowing over finish as it can trap active solvent from off gasing.
C) atomized air at the gun 16-24 psi
Too much air will cause premature skimming.
Hope this helps
12/3/24       #4: conversion varnish looks slightly m ...
stoneaxe Member
Thanks for the replies.
The manufacturer info says spray temp. minimum is 68 degrees F.
Not sure about what pressure the applicator is using.
It is not flattening agent as far as I can tell.
12/21/24       #5: conversion varnish looks slightly m ...
Jim Clark Member
Are you using lacquer thinner for thinning?
If so, I bet that is it.
Most lacquer thinners today are reconstituted junk containing
a lot of water.
I now use automotive urethane reducer to thin my CV.
Gives much better results.
12/21/24       #6: conversion varnish looks slightly m ...
stoneaxe Member
Not sure if the finisher is using a reducer- I will check. There is a bit of a break in our production so no recent results to look at.
I will set them up with some samples to see if the problem can be isolated- it has the potential to be devastatingly expensive, as there does not seem to be any corrective action that can be taken , except re-milling the entire job. .
On a side note, throughout my career, maintaining quality from sub's has been the single biggest stress.
    • 2Sand
