CV burnishing/shiny spots
12/18/24
Travis
Hello. I spray ChemCraft CV. I have gotten a few call backs in the last several months about shiny spots. This shows up when the contractor/painter/customer tries to clean the cabinets. They are causing these areas to burnish for lack of a better term. I've experimented and it doesn't take much rubbing to cause this. Is this common for conversion varnish or is it specific to this brand? I typically spray 20 sheen.
12/24/24       #2: CV burnishing/shiny spots ...
Doug Harris
Which CV? Paint or Stain? Send a Picture. What are they cleaning with, other that Mind Soap and Water maybe the problem? Is the Finish Lifting off the Surface? If they are using any Elbow Grease, pressure the Flatter Finish Will polish or Shine more?
We started Cleaning our own Cabinets as a punch Item. We have had over zealous cleaning screw up cabinets.
We had a cleaning person sit some kind of "Green" cleaner on a light color Granite Top and it left a Green stain? Was not my problem but the Granite Guy had to replace the Island Top.
12/31/24       #4: CV burnishing/shiny spots ...
Travis
We use ChemCraft Chem24 CV, 20 sheen. There doesn't have to be any cleaning product used. Just simply trying to wipe off a smudge will leave a shiny spot. And color doesn't matter-it does it on white, gray, blue etc.Is this a common problem with CV? I'm more experienced with pre and post cat lacquers. Thanks
