Excite spray gun issue
12/30/24
Nick Sinderson
My fairly new and rarely used excite gun has developed and is stuck on a 2" wide spray pattern. I've taken apart and cleaned every part and made sure they work, all the gaskets are in place and are in good shape, the spreader works, air cap is clean and l've tried new tips all without success.
12/30/24       #2: Excite spray gun issue ...
Well the action of the turn knob on the rear of the gun is what determines the width of the fan pattern. More air passing through the fan pattern valve makes the fan smaller. When you turn the knob and close the valve it should produce the large fan and when you open it up it should produce a small pattern.
It's a very simple operation, hard to corrupt it. And I'm not even sure if there is a gasket/Oring in there. I think it's just milled into the body of the gun.
12/31/24       #3: Excite spray gun issue ...
herb johnson
one, the fan control might be bent
two. the aircap is clogged
three. the white oring on the outside of the fluid outlet, not the white tip gasket inside the tip, is either missing or cracked
good luck, herb j
12/31/24       #4: Excite spray gun issue ...
Nick Sinderson
Thank for the replys. I've been doing this work for awhile (close to 50 years so l know how a spray gun works and how to clean one). That's why l'm stumped...l'm guessing it's the air spreader, (air fan control) but l've taken it out and lt works and l've cleaned the passages (they were clean) l'll just buy another spreader. Once again, thanks.
12/31/24       #5: Excite spray gun issue ...
herb johnson
nick unless the tip of the air adjusting valve is worn or bent, it is not ur issue
