Exterior Window Shutter Finishing
1/20/25
Michael R
Looking for a little guidance here.
I'll be making new exterior window shutters made of Douglas Fir lumber. I would like to spray the pieces that make up the shutter before assembly. I have a Kremlin 15C25 pump and an Apollo turbine. Rather use the Apollo.
I don't want to paint these by hand so I wonder if this group can lead me to the proper sprayable finishes for this project. The customer choice of color is Hunter Green.
Thank you.
1/23/25       #2: Exterior Window Shutter Finishing ...
Mitch Suber Member
The best recommendations I have had over the years for exterior shutters has always been oil based primers and latex paints. In the last decade I have used some water based primers. They seem to be ok, and they certainly help with faster drying. This is nice when spraying certain parts prior to assembly. I do always stay with good brands, my preference in my area is Sherwin Williams, Benjamin Moore and Richard's has a couple of exterior paints I like. I'm not sure how these products will work with your equipment, we typically apply using pressure pots for paint and sometimes gravity fed guns for primers. A lot of my experience with finishing exterior shutters came from the specifications and experience of doing historical restoration work,
1/23/25       #3: Exterior Window Shutter Finishing ...
Michael R
Thanks, Mitch
Yes, I was looking at Sherwin-Williams latex primers and paints and the PSI and tip sizes for air-assisted airless are right for me. I sprayed Sherwin-Williams extreme bond primer before and I don't know why I thought exterior paint would be any different but through my research, I'll found out that the PSI is practically the same. So I move forward with a high-grade primer and paint from Sherwin-Williams.
Thanks again!
