FF Inset finishing
3/16/25
Sean
The shop i work at is delving into Inset FF Cabinets. They are building FF, attaching to boxes (leaving the back out and putting on after finish), ordering the doors, finishing everything and then assembling everything after finish. By assemble, I mean literally installing hinge plates, guides, backs, everything after finish. My boss is pulling his hair out putting everything together as the door seams vary and are all over the place. The cabinet maker swears it's because the wood moves after construction and we need to get them finished sooner after his build. For context, these cabs can sit for 3 weeks before finish as they stay a whole house ahead of finish schedule. Before finish, we prep sand everything (because of course wood does move a bit and needs a fresh sand). I'm of the opinion the cabinet maker is outsourcing the doors and not sizing them before finish to each opening. Opinions welcome
3/16/25       #2: FF Inset finishing ...
Using measurements for inset doors isn't likely to work well for you. Inset is my wheelhouse and I build the FFs and doors and then use shims for sizing to fit the doors. I use to do 5/64 margins but they really turned out to tight for all situations so I've gone to 3/32 margins. So you either take two 3/32 shims or a 3/16 shim and put the door in the FF and size it until the shims are snug.
If you are making FFs and ordering doors (from anyone) and finishing without fitting them you get what you put into it. Inset isn't anything like a 1/2 overlay with 1/2" margins. If you are off a 1/16 it won't matter much. If you are off a 1/16 on inset it's make or break.
As for door sizes moving around, it happens and in the width mostly. If they were sized correctly and at 6-8% when milled then they will settle back to the correct size if they dry out or swell from humidity variances in your shop environments.
I make my FFs first, then doors, then fit them and only then put the FFs on the cabinets. If you are using FF plates that attach to the rear of the FF then bore the holes in the doors and mount them on the FF, then removed them. That way you have the holes and they are all positioned correctly. Ya, it's way more work than you are use to. That's what you get with inset.
3/16/25       #3: FF Inset finishing ...
Sean
Leo G, thanks for the response. I figured as much, I just wanted to hear opinions from others to make sure I wasn't crazy. I've been finishing at custom hi end levels for 30 years and recently moved from that market to a "slower paced" environment as I'm older now. How you described it is exactly how I've seen it done by the cabinet makers where I come from. The owner is of the same opinion. Sadly, I'm dealing with a "blame the finish" kind of cabinet maker.
3/16/25       #4: FF Inset finishing ...
Ah yes. The painter will fix it. More of an in a house type expression but fitting still the same.
The one thing I've learned is the professional finishes we spray hide nothing. It's all in the prep. And if the carpenters building the stuff are leaving the final prep to the finisher it's going to be the biggest bottleneck ever. Hard enough to just keep the spraying going without having to stop for every little gap or hole that wasn't seen and filled.
Even when I'm doing Euro cabs it's the same issue. Small margins equals precise fitting which usually means you need to assemble the run of cabinets and lay the doors on top to make sure you aren't experiencing "addition overlap". Meaning the measurements of all the doors and spacing is correct but they aren't lining up at the edge of the cabinets like they need to. Again, I use 3/32 margins and not 1/2" like lots of other shops.
3/16/25       #5: FF Inset finishing ...
Sean
I understand exactly whay you're saying. It's a collaborative effort across all members of the shop to achieve real good custom work. My finish will only be as good as your substrate so to speak. I've always delineated sanding into two phases...."Rough prep" and "finish prep". I expect the fabricators to remove their glue (trying to get guys to just use a damp rag during glue up is like pulling teeth out here) and remove the major mill marks. I'll then follow up and finish prep everything to my desired spec based upon the finish I've developed. I don't expect fabricators to worry about filling holes (I don't like people trowling putty on holes and creating flat spots in the grain) or sanding to specific grits, that's my job. I may want the wood sanding with 150, or maybe 220, i may want to wire brush it,, etc. My finish prep can vary wildly depending on whay im doing. Am i staing maple, or walnut.....completely different prep process. Am i using dyes or pigments, am i gold leafing it, am I glazing it, am I doing a full fill buffed gloss polyester finish, it goes on and on, but I feel that t if I have to touch the wood with anything courser than 150, then it isn't clean enough of a build. Just my way of doing things.
3/16/25       #6: FF Inset finishing ...
Hope you have a helping in your sprayroom.
I don't
