Blushing troubles
7/13/25
Keith Farr
Im a cabinet shop owner with a finishing department relying on a employee who has much experience in finishing but is having Blushing issues. He shoots AMARIUM precat conversion lacquer over our lacqeur painted cabinets and our stained cabinets. We have a knotty Alder job that was stained , sealed , glaze applied , then sealed and fished that started blushing about 10-14 days after it was shot.( cabinets are allready installed ) It has been very humid here in Texas for last month. We installed a 14 x24 Colmat spray booth about a year ago. For years we just spryed in a large room with exausht fans and such with no problems. and we never have problems except with stained cabinets. We have been bringing doors back to shop and trying Mohawk blush remover in a rattle can with limited success Any suggestions?
7/13/25       #3: Blushing troubles ...
Are you staying within your brand system or are you mixing different products to get your final outcome.
Using oil based stains under modern finishes can cause issues. Usually you'd use the recommended stains so you stay within the system.
I'm just noticing you said you coated with lacquer and then overcoated with precat. Nitrocellulose lacquer is know to blush while most modern pre and post cat lacquers won't even under extreme humid conditions.
7/15/25       #4: Blushing troubles ...
FM
I would not call it blushing if it’s doing weeks afterwards. Blushing is immediate. My experiences guess? You have separation between two coats. Have you blue taped a section that is effected, cut a grid pattern in with a razor blade and pulled the blue tape to check for adhesion?
    • 2Sand
