Spraying Latex with AAA
8/15/25
Brian Russell
Website: http://billferrell.com
I have been using a CA Technologies 14:1 AAA pump with Bobcat gun to spray water borne clear coats for about 5 years with very good success. I recently purchased a second unit to spray latex type pigmented paints (typically Benjamin Moore Scuff X) and I am have terrible problems with the tip clogging. I am using a 617F tip and usually I can only go a few seconds before the tip clogs. Sometimes a stiff brush with water can clear it out, but often I have to take the tip out and clean it out. Does anyone have any experience with this type of setup and product?
8/15/25       #2: Spraying Latex with AAA ...
herb johnson
if u r spraying with a fine finish tip, u need to increase the gun handle filter. are u spraying with the other gun a fine finish tip.. also are u agitating it before spraying. remember the fine finish tip has a pre orifice in the spray tip which pre atomizes the coating, it is also a smaller opening i believe than the tip so that may be causing the clogging keep me posted and we will work this out
good luck
herb j
8/15/25       #3: Spraying Latex with AAA ...
Brian Russell
Herb,
I am not aware of a fine finish tip specifically. I am using the opti tip which is supposedly better for water based finishes. I believe the only difference between the standard tip and the opti tip is that there is an additional small piece that fits inside the tip right before the orifice. I can remove that if you think that is the issue. I also see that they sell a small tip strainer that replaces the o ring that is right before the tip, I could purchase one of those as well.
8/15/25       #4: Spraying Latex with AAA ...
herb johnson
does ur other gun that sprays with no problem have the opti tip? if it doesn't just remove the plate behind the tip and u should be fine as it is proven that that combo without the pre atomizing plate is causing ur issues. lets find out about the other tip and don't buy anything yet
8/15/25       #5: Spraying Latex with AAA ...
Brian Russell
Both of the setups have the opti tip in. I removed it from the new unit that is running the paint and it seems to be doing well. I shot a couple of gallons and it never clogged, so hopefully that will fix the problem.
8/16/25       #6: Spraying Latex with AAA ...
herb johnson
beautiful, glad it worked out... and it didn't require any $$$ to fix
good luck
herb j
9/7/25       #7: Spraying Latex with AAA ...
Alec
I don't have experience with that exact AAA, but plenty with the Graco FinishPro and G15/G40 guns, which work much the same way.
Make sure you're cleaning your machine and gun filters regularly. Paint particles build up in them and will occasionally get through the screens to clog your tip. The more frequently you clean your filters, the less frequently you will get clogs. Also, strain your paint first using a fine mesh nylon filter bag available from any paint store. And lastly make sure you're using //soap// and warm water to clean your equipment. I use dawn dishsoap, which for me has worked spectacularly. For years I only used warm water, which does a so-so job but leaves plenty of material behind in the hose that eventually begins to contaminate the new material you spray, leading to gunk buildup and, eventually, tip clogs.
Last but not least, sometimes you just need to increase your pressure.
Hope that helps!
