Clear Base VS White Base
8/28/25
Dave Member
Website: http://north52cabinets.ca
Hey guys, quick question. So does anyone else have issues with spraying a clear based dark laquer? For the life of me everytime we spray a dark colour that is clear based we end up with speckles. No matter if its done by hand or on the flatline. Anything white base comes off like glass. Were mixing as per our mix master and the same results everytime. Any help would be awesome, thanks in advance
8/28/25       #2: Clear Base VS White Base ...
FM
Usually the complaint is the dry time and softness of the clear darker pigmented colors. Speckles is easy to tell you the problem but takes a lot of effort to fix. It’s about having a cleaner environment and equipment. You’re picking up the dust and particles from all those white toned paints that stick to every surface, filter and line. Time to shut things down, blow off everything all the way up to the ceiling, really clean equipment deep and then fire back up.
8/28/25       #3: Clear Base VS White Base ...
Are you running inline filters? I remember when I first got my Kremlin pump I swapped over from a pigmented white to just a plain clear and the white crap I had to deal with was never ending.
I had a filter at the bottom of the gun but the tip in the gun was just an O-ring. I replaced the O-ring with a filtered O-ring and the issue stopped.
Now the only things that get into the finish are things floating in the air. Keeping the fan on in the booth before, during and after spraying keeps the air clean as long as your intake filters are clean.
And as FM said keeping the area clean helps a lot too. Or spray the area down with a mist of water to ground any dust.
9/9/25       #4: Clear Base VS White Base ...
NJ Furniture Mart  Member
Website: https://www.njfurnituremart.com/
Dark, clear-based lacquers tend to show pigment separation more easily. Try extending mix time, straining before spraying, and adjusting air pressure or reducer ratio. A slower reducer or retarder can also help pigments lay down smoother without speckling.
