Refinish kitchen table top
8/7/25
I am a professional but I don’t do finishing. I have a table that is used for a kitchen table. The finish over years is getting gooey and a little milky around the edges.
I’d like to give it a light sanding to clean off the worn finish and top coat it. I think the finish is lacquer. You will get a white cup ring if you leave a moist cup on it. It will go away over time.
Any help is appreciated.
8/7/25       #2: Refinish kitchen table top ...
Sounds like it's nitrocellulose. A very soft finish. If you take some Denatured Alcohol and wipe a small area does it strip the finish?
8/11/25       #3: Refinish kitchen table top ...
John Gossling
No matter what the finish is, it needs to be removed if it is gooey.
10/24/25       #4: Refinish kitchen table top ...
David William  Member
A light sanding and a fresh topcoat is a good plan. Since it’s likely lacquer, make sure to remove all the gummy residue first and use a compatible lacquer or wipe-on finish. Test a small area first to ensure it blends and cures properly without raising the wood grain.
