Clear Coating Maple without Yellowing
12/12/25
Michael R
What preparation must I follow in order to clear coat bright hard rock maple without changing its original color? Whenever I use for a sealer under my clear coat, I get a little bit of yellowing. Is there a way to keep the original unfinished wood color? Thank you.
12/12/25       #2: Clear Coating Maple without Yellowi ...
Chemmy
Use Acrylic coatings, SW, Delta, or others that are acrylic/cab coatings for indefinite non yellowing.!!
12/12/25       #3: Clear Coating Maple without Yellowi ...
Michael R Member
Thanks Chemmy!
I have been using Sherwin Williams Gallery clear coat, which is an acrylic and I still get a slight yellowing after spraying. Just to be clear, I'm not concerned about it yellowing over time because I am using an acrylic, I'm just trying to keep the bright Maple bear wood color using a clear coat. Are the products that you are recommending (solvent-based) designed to completely stop any yellowing? I know in your first reply to me, you used the words "indefinite non-yellowing. Should I expect a slight transformation after three coats, or should I see through it as if it were glass?
12/12/25       #4: Clear Coating Maple without Yellowi ...
cris
Whitewash then clear. you will have to experiment with it. We did this years ago and it worked great.
