Spraying short boards in volume
7/12/26
BH Davis  Member
I'm going to be shooting latex paint on 1x4x(2' to 3') lengths of PVC part in volume. The PVC will be properly prepped and ready for paint. I may or may not shoot a bonding primer.....yet to be determined.
The paint is being applied to one face and all four edges. I'd like to place the boards directly on a spray table surface without raising them up with any sort of lift sticks. This will keep overspray from getting underneath and onto the backs. If that happens I can sand it off but would rather avoid that step without having to first mask the backs.
So the question is what material to use to cover the spray table that the paint won't bond to thus causing problems. I'm thinking of laying out waxed paper and seeing how that goes. If the paint doesn't stick to the wax paper I'll still likely have to lightly sand the back edges to rebreak/smooth out the edges after painting. Anyone have any experience with this sort of situation?
Thanks,
7/14/26       #2: Spraying short boards in volume ...
nicko
Can you buy a roll of rosin paper or brown paper from Home Depot and put a dowel through it and make it like a paper towel dispenser at the end of your table. And pull out the paper across your table and spray on it then just keep cutting it off with a razor knife and pull out another section and repeat.
You could make a quick dispenser out of a dowel and some scrap wood and mount it at the end of your table.
7/14/26       #3: Spraying short boards in volume ...
BH Davis  Member
Thanks for the reply. Unfortunately paper is not going to work. The whole point is to not use something where the paint will wrap from the 3/4" edge of the material down onto the table surface material. The paint would create a bond between the edge of the PVC boards and the paper. The result is that the paper will tear as the PVC is removed after painting and then have to be razor cut free from the PVC. I've been down this road many times which is why I'm looking for a material where the paint won't bond to the substrate.
It is a clever idea though. Early on in the CNC years back in the late 90's to early 2000's I did that paper roll idea at the end of the CNC table. Before getting the SL Laser that projected our curved moulding locations onto the CNC I set up a 6' wide roll of cardboard factory roll ends on top of upside down casters to create just what you are describing. Then a magic marker mounted in the spindle (not spinning of course) would draw the part location on the paper. Our vac pods were then mounted to the table inside the moulding lines to hold the blanks down during cutting. After 10 or so mouldings the paper would have so many magic marker lines on it we'd need a new sheet. We'd just cut off the old one and pull the paper off the roll TP style right up onto the table for a new surface.
7/14/26       #4: Spraying short boards in volume ...
Nicko
I was assuming you would be picking them up and moving them to a drying rack as soon as you sprayed them. Before the paint dried. Then roll out a fresh piece so you’re not laying them on to the wet paint you just sprayed.
7/14/26       #5: Spraying short boards in volume ...
BH Davis  Member
Ahh........yes, that would be nice. But there is really no way to pick them up with the edges as well as the face painted. It would make them much easier to paint as vs. spread out across several tables. But let me think more about that. Perhaps I can come up some sort of lift device directly under one end that would allow me to raise it and get my fingers underneath after painting. Thanks for the follow up.
7/15/26       #6: Spraying short boards in volume ...
nicko
I don't know how many you have to spray but cheap 5mm luann ply wood cut slightly larger than what you have to spray would allow you to pick them up and set them on a drying rack. You would need one for each piece. Or a small 18 gauge nail in one end would let you pick them up but then you would have a small hole to touch up.
7/15/26       #7: Spraying short boards in volume ...
BH Davis  Member
Actually you sent my mind in a totally different direction. What I think I didn't state in the original post was that the plan was to do large table layouts of 10 to 20 pieces. Then move around the table with the spray gun doing all the edges from each of the 4 table sides, with a final spray over of the top faces. Then move onto a 2nd and then 3rd table. About 60 to 65 parts to spray in this first run.
Now I'm thinking of going your route of bringing out the rotary spray table and doing them one at a time. I'll do some experimenting but I'm thinking that if I use a 3" to 4" high riser block, somewhat smaller in width and depth than the parts, I can spray down at about a 45° angle to do the edges as I spin the table. At that angle and part height I shouldn't get any spray bounce back from the table surface up onto the back of the part.
That leaves plenty of height and back exposed to grab with my fingers to move the part to a drying table with stick risers. The test will tell the tale but I'm optimistic this will work.
Thanks for the 2-heads are better than one back and forth.
7/16/26       #8: Spraying short boards in volume ...
Tyler
I’m wondering if you built a ladder style frame from 3/4 or 1/2” plywood with the edge oriented up and laid all the parts on top if that would eliminate most of the overspray? Similar to a cabinet base.
Could be multiple and just spray and leave to dry.
7/16/26       #9: Spraying short boards in volume ...
BH Davis  Member
So are you're thinking 2 vertical ladders, one at each end of the 26" to 30" long blanks? And the blanks would sit on the rungs an inch or so from their ends? Not a bad idea. Perhaps make the ladders with 3/4" sq. sticks and 1/4" dowels for the rungs. Not any harder then cutting 1/2" ply ladders out on the CNC.
7/16/26       #10: Spraying short boards in volume ...
Michael Member
Website: http://todrinfinewoodwork.com
There is a product called anair shim which is basically a plastic bag with a bulb attached to it. Give the bulb a squeeze and the bag inflates.
If you put your workpiece(s) on the bag(s) you could spray, give the bulb a pump. That should create enough lift to pick up your piece and put it on the drying rack.
Here is a link to the product. There are many similar options.
https://garrettwade.com/products/pneumatic-lifts-set-of-2?gad_source=1
&gad_campaignid=19684667925&gbraid=0AAAAAD_D1MfrjXAIrbG87owqIwZV02v33&
;gclid=Cj0KCQjwguLSBhDLARIsAH-yPrELH7iZTZBow5QBdemrloQKzHt9Z0EpxCuy1AtJxp0vIcid4p
gCCvcaAk8sEALw_wcB
7/16/26       #11: Spraying short boards in volume ...
BH Davis  Member
Thank you Michael. I'll check them out.
7/22/26       #12: Spraying short boards in volume ...
JeffA
I used to use double edged tape to hold down small and numerous pieces on sheets of mdf or whatever. the tape raises up the parts just enough to not have a paint build up and you can actually do a 4x8 and paint many pieces at a time.
7/23/26       #13: Spraying short boards in volume ...
Bart
If you're only doing 10-20 pieces at a time you can use 2" 3m blue tape. You crease it down the middle and wrap onto the under side of a piece of plywood. Make 2 rows, near the top and bottom. It acts like double sided but will keep your parts free of the surface. I've been doing this for decades for cabinet door stop. Typical batch of 20+ doors is 80 pieces of stop. It's sticky enough you can sand them with synthetic steel wool.
my 2cts
7/27/26       #14: Spraying short boards in volume ...
BH Davis  Member
Thanks everyone for the discussion input. In the end nothing was perfect and I had to sand the backs to get off some over spray. However I put them through the wide belt at a fast speed and 220 grit. Then a quick once over with the random orbit with 220 and they were clean. All in all not that much extra work. There were about 65 pieces in this initial run.
However next time I may give the tape methods described by JeffA and Bart a try. Those suggestions came in after the project was already through the painting process.
Also some of the PVC I got for the project had peel off protective plastic sheet applied. As long as I can still get that in the future I'll be leaving it in place during painting process and it will become the back of the parts. That should be the ideal situation. Paint fronts and edges and then peel off the back side plastic. Rear masking without having to apply Oramask.
