3m powered respirator cartridge replacement interval
9/11/26
Gerben Member
Hi
I recently bit the bullet and went from a fullface 3m mask to a powered respirator
Got the tr-600 kit
Using the 6530 filters, (they are for acid gas)
I spray catalyzed conversion varnish
After about 15 hours they are done, when i turn on the unit, it blows a pretty nasty smell of lacquer
I called 3m, they said 15hours seems quite short
Anyone out there using the same setup that can tell me how long their filters last?
Considering the cost of these filters (over $200 each here in Canada)
Could say " but once, cry once" but once you have the mask you'll ending spending much more on filters.
It becomes unaffordable to use this setup.
