Forestry
Tree/lumber damage
8/27/17
Joel Patrick
Here in Northeast Iowa we've been invaded by Oriental Bittersweet. It's a "strangle" vine and is literally taking over much of the woodland. Many of the smaller trees are losing out to this plant. Young walnut trees, for example are being killed. When you pull off a vine that's embedded itself in the trunk there's an inch-deep permanent scar that's left.
Just cutting the vine doesn't accomplish much, because within 3o days the vines are back. Have any of you had experience killing this thing? Does Roundup work?
8/28/17       #2: Tree/lumber damage ...
Mark Hineman Member
I've not treated that specific vine, but I have done TSI to remove Grape vines, Autumn Olive, etc.
The best time to treat them is late summer and fall when the plants are moving sugars down to the roots, so the chemicals will move there also. In the spring the sap pushes the chemical out so it is not effective.
Generally the best thing to do with vines is to cut them at waist high or above so they can't reach the ground and root back. Then treat the bottom cut vine with herbicide. I use straight 25% Glyphosate (Roundup). Do not dilute it.
Use a small handheld "spray bottle" with the pump plunger on the top from TSC or Rural King. Only pump it up with a few pumps as you only want the liquid to squirt out in a stream that will go a few inches and not spray. Then squirt that liquid on the cut end of the bottom vine or cut stump of Autumn olive, etc.
