Forestry
Pin Oak loosing bark when dead
12/3/20
Alan Kitzhaber Member
Some of the Pin Oak on my land will readily loose there bark when dead while others hang on to their bark and rot from the inside out. Does anyone have an explanation for why this happens?
1/3/21       #4: Pin Oak loosing bark when dead ...
rich c
One reason could be the pest that is attacking the tree. Depends if it's a root disease or pest attack. Many pests feed on the cambium layer and if that is destroyed, it's easy for the bark to fall off.
1/4/21       #5: Pin Oak loosing bark when dead ...
ALAN KITZHABER Member
Thanks for the reply. That sounds like a reasonable explanation. I've wondered if it is the time of year that it dies. If it dies in the spring when the cambium layer is growing and more loosely attached to the tree. Oak wilt would probably account for most of the trees dying. That can be transmitted through a broken branch or through the root system.
    • RT Machine Co.
    • Original Saw Company
      Industrial Radial Arm Saws
    • Lignomat
