Forestry
question about oak trees
8/21/23
Chris
I had a 15-year-old oak that was cut down in my backyard and I want to use the wood to build some shop furniture. Do I need to dry the wood in a kiln or can I use the sun to do that? How long does it need to be dried (kiln or otherwise) before I can safely use it?
9/1/23       #2: question about oak trees ...
Dave Edgerton  Member
About 1 year per inch of thickness usually. You can build a mini solar kiln for it. Lots of ideas online.
11/22/23       #3: question about oak trees ...
Ninareyes Member
Yes, you need to dry the oak wood before using it for shop furniture. Sun drying is a viable option, but it can take several years to reach the desired moisture content of around 6-12%. Kiln drying is a faster method, typically taking a few weeks, but it requires specialized equipment. Regardless of the drying method, it's essential to monitor the moisture content regularly to ensure it reaches the appropriate level for furniture-making. Once the wood reaches the desired moisture content, you can safely use it for your shop furniture project.
12/30/25       #4: question about oak trees ...
TomMath11 Member
Website: https://puningroup.com/vacancy/
Both methods work, it just depends on patience and end use. Air drying (or solar kiln) is fine for shop furniture, but oak needs good airflow and careful stacking to avoid checking. Like Dave said, a rough rule is about a year per inch to air dry, then you can bring it inside to acclimate before building. A moisture meter is really helpful — once you’re around 8–10% indoors, you’re good to go.
If you’re seeking opportunities abroad, check out Cyprus job listings
for current vacancies and career options available in Cyprus.
