Furniture Making
Subject: Re: Smooth oil and urethane finish
11/11/18
Dave Member
Hello. Want to get a smooth semi-gloss finish on a refinishing job. Iím using arm r seal oil and urethane wiping finish. The customer is anxious to get the furniture back so waiting for the cure time is not an option at this point. Is there a way to get a final smooth finish in a shorter period of time? Dust is an enemy in my shop and Iím finding it impossible to have a dust free finish. Thoughts and experiences would be very helpful. Thank you.
11/11/18       #2: Smooth oil and urethane finish ...
John Member
Higher temps., low RH, and air moving across the finish will speed up the drying. 70F, 50% RH or lower, and a gentle breeze from a fan across the room work well. Thin, wiped on coats dry a lot more quickly than coats that are brushed on. But I apply the first coat heavy in order to fill the pores, then wipe off the excess after a few minutes.
John
11/12/18       #3: Smooth oil and urethane finish ...
Dave Nauman  Member
Website: http://www.dcnchair.com
Shellac.
11/12/18       #5: Smooth oil and urethane finish ...
Dave Member
Thank you so much for the reply and new wisdom!
11/14/18       #6: Smooth oil and urethane finish ...
Bryan "doc" Henderson  Member
Is the wood walnut? I have made many things with walnut and used danish oil. Watkins also makes a finishing wax to top it. It can be handled ASAP and used in 8 hours. The finish is more of a satin but the real wood shines through. In the future you can just light sand and re-coat. Or you can spray a spar urethane over this. I also have a salvage hospital blanket warmer for smaller projects and can re-coat every 30 minutes or so. In my sons pine wood derby days, we used radiant heat from the bulbs you buy at farm stores to get the surface temp up. The finish flows better and dries quicker so does not get the dust. For small projects I use rattle cans and put these (cans) in the warmer to pre-warm the urethane. It increases the pressure (caution) in the can and actually sprays better. I am a hobby guy so take it for what it is worth. I had a family friend stop by last week from another state. I pulled a military image of her husband from face-book, laser engraved it on maple, put on 3 coats of urethane and gave it to her in 2 hours. she is from out of state so did not want to ship. Regards
11/14/18       #7: Smooth oil and urethane finish ...
Is the wood walnut? I have made many things with walnut and used danish oil. Watkins also makes a finishing wax to top it. It can be handled ASAP and used in 8 hours. The finish is more of a satin but the real wood shines through. In the future you can just light sand and re-coat. Or you can spray a spar urethane over this. I also have a salvage hospital blanket warmer for smaller projects and can re-coat every 30 minutes or so. In my sons pine wood derby days, we used radiant heat from the bulbs you buy at farm stores, or WM, to get the surface temp up. The finish flows better but dries quicker so does not get the dust. For small projects I use rattle cans and put these in the warmer to pre-warm the urethane. It increases the pressure (caution) in the can and actually sprays better. I am a hobby guy so take it for what it is worth. I had a family friend stop by last week from another state. I pulled a military image of her husband from face-book, laser engraved it on maple, put 3 coats of urethane and gave it to her in 2 hours. she is from out of state so did not want to ship. Regards
11/14/18       #8: Smooth oil and urethane finish ...
Dave Member
Thanks so much for the information. I ended up putting several coats of out and urethane until the wood stopped absorbing the finish over the entire area. After the final coat dried (24 hrs) I wet sanded 1000 to 2000 grit. I want happy with the sheen. It ended up being more satin. After the wet sand I cleaned it up and let it dry. Lastly I put one last thin coat of the oil/urethane on it and it turned out beautiful and smooth. Iím most definitely still leaning. I think I need to upgrade to a spray system.
11/14/18       #9: Smooth oil and urethane finish ...
John Member
That looks very nice Dave; glad it turned out well.
You can bring the sheen up to any level you want with MicroMesh, 3M's Trizact, etc., or automotive buffing and polishing compounds.
Wax and 0000 steel wool gives a beautiful satin sheen on Arm-R-Seal.
John
11/14/18       #10: Smooth oil and urethane finish ...
Dave Member
Thanks John. And thank everyone for the experience!!&#129308;&#129307;
    • Anver Corporation
    • CP Adhesives
