Furniture Making
Subject: Re: Table/leg finishing
Table/leg finishing
11/15/18
Dave Member
I have been learning a ton on this site as far as finishing goes and with a little luck maybe my questions can become answers to others. I am refinishing my first table for a customer. I understand the process involved except for one thing. I’m using the rock hard tabletop finish for the table.
1. Can I put shellac on the bottom of top and the other unseen areas for a sealing purpose.
2. Do I use the same finish for the legs as I did for the top.
3. Can I thin the finish to be used as a wiping finish or for longer dry time.
Thank you&#129308;&#129307;
11/15/18       #2: Table/leg finishing ...
Dave Member
I almost forgot. I was also wondering if I can rub out the satin(after curring) to a semI?
11/15/18       #3: Table/leg finishing ...
duster
1. yes. It's a good idea to seal the underside of table tops
2. yes. I can't think of reason not to use the same finish.
3. I'm not familiar with rock hard tabletop finish, but if it's shellac I'd say no. Shellac is thinned with alcohol and it dries too fast.
4. it might be possible, but you'd be better off applying a semi gloss product if that's the result you're looking for.
11/15/18       #4: Table/leg finishing ...
Dave Member
Makes sense. Thanks
I have a gallon of premixed waxed shellac and I was hoping I could just use that for under the table
11/17/18       #5: Table/leg finishing ...
John Member
I would use the same finish on both the top and bottom of the top, so that moisture exchange is equal.
Most varnishes can be thinned to make a wiping varnish. Try it on some scrap.
If you want a semi gloss, rubbed out finish, start with gloss. It will look better when you're done than if you start with satin.
John
12/7/18       #6: Table/leg finishing ...
Use the same finish top & bottom so the wood is affected the same way when changes in moisture occur. You can dull a glossy finish but you can't make a duller finish more glossy. The gloss level is controlled in the finish by adding a flatting agent. No amount of polishing will remove it. You can use a different finish on the legs if you want a different look. Might be a good idea if you are using a hard finish on the top. Hard finishes chip more easily and legs are prone to getting hit.
