Furniture Making
Subject: Re: Curved bottom table.
3/28/20
JK Member
I have a client who is looking for a circular base table with a curved bottom top that is 26" round. I was going to have it done by CNC but I was wondering if there was another way to do it.
Thanks.
Byers_Dunne_side_table_3_3_revised.pdf
3/28/20       #2: Curved bottom table. ...
Any woodturner with a big enough lathe could do that.
3/28/20       #4: Curved bottom table. ...
Thomas M Diel  Member
Website: http://thomasdiel.com
Rich's idea has the most plauisble merit if your stack laminating, but it would be top heavy if solid. Most turners would want to do it as a solid.
If it hollow turned bowl like 3/16" - 1/4" wall with a drop in top (or drop over top w/ rabbet) in some type of lipped edge I would keep them together thru the duration. Also have and expansion gap like in 5pc door to allow for differential movement. Also equal amounts of finish all side in & out.
If it's a solid color you could find something off the interweb and a quick search turned up a couple suitable 24"dia x 6" bowls and use those as a positive mold to create negative and fiberglass your version and drop a suitable moisture resistant MDF top in? Still a bunch of labor, but lighter in weight.
Wendell Castle did examples of both stack laminations and fiberglass forms.
Good luck,
TD
