Furniture Making
Subject: Re: planked table top
planked table top
4/5/18
Richard Tadrzynski Member
When gluing up 6 x 72 x 1 in thk ash for a table top,
can you cross brace the back to prevent cupping??
4/5/18       #2: planked table top ...
Why will it cup? Is it kiln dried?
Wood moves in response to changes in its moisture content. Once in service as a table, do you expect it to be subjected to wide swings in relative humidity?
Cross braces below can be added, but you must allow for normal (or abnormal if the wood is not properly dried) seasonal movement when attaching the cross braces.
First Table?
4/5/18       #3: planked table top ...
1" thick stock is called planks now? Sounds like a Crate and Barrel term.
4/5/18       #4: planked table top ...
rich tadrzynski tadrzynski Member
Thanks Dave for the informative answer you posted. Actually, it's my second table and I wanted to avoid the mistakes I made in the first one. I appreciate the questions you asked because it gives me another path to completing a satisfying project.
As far as Rich C's helpful answer, Jeez, I just don't know, planks is just planks to us stupid uneducated Pocono mountain people!
Much appreciated
Rich T
4/28/18       #6: planked table top ...
Paul Eichenlaub  Member
Website: http://Www.pauleichenlaub.com
You may want to let us know what the mistakes were on the first one to make sure its not done again.
4/24/20       #7: planked table top ...
Gabe O Member
A table made this way needs a cross grain section like breadboard ends, steel, etc to hold it flat or it will warp that is guaranteed. Kiln dried or not. The trick is attaching opposing grain material and allowing expansion/contraction.
Some of these guys clearly know it all.
