Furniture Making
Subject: Re: waterfall edge clamp
4/25/20
Jason Member
Has anyone tried using the granite suction cup clamps for a wood waterfall edge glue up. I usually use wood blocks that I CA glue to the sides and then pull a clamp across them to close up a waterfall edge. I'm doing a larger table this time and the grain is ripping out from the CA glue. Looking for alternatives and a buddy who does kitchen cabinets told me he saw a granite guy with a 90 degree suction clamp use it on a granite waterfall. Just looking for a better and easier way to clamps waterfall edges.
4/25/20       #2: waterfall edge clamp ...
I make cauls with a cleat cut to 45 degrees. One of each gets clamped to the top with the center of the angled cut, centered on the waterfall miter. Then use F clamps from cleat to cleat to pull the miter closed.
4/26/20       #3: waterfall edge clamp ...
Mark
You might have better luck with a paper joint on a 45 degree caul. Paper joints hold pretty tight and break pretty clean leaving just a bit of paper and glue to clean up.
    • CP Adhesives
    • Anver Corporation
