Furniture Making
Subject: Re: Compressed wood for bending
6/24/20
Elia Bizzarri
Website: http://handtoolwoodworking.com
I have built a press to compress 1-1/2 x 3/4 x 16" pieces of solid wood prior to bending into a s-curve. Similar to what is happening in this video: https://www.youtube.com/watch?v=XOGBZH_q7RI
I am hoping to use this in production runs of tool handles.
I am getting compression failure on the end of the part that is closest to the press's cylinder after about 18% compression. I am using 25% MC riven white oak.
Questions:
What's the advantage of pre-bending the part in a bending strap before using the press?
Does the speed of compression matter?
How tight should the part be in the chamber in which it is compressed?
Thanks!
Elia
6/24/20       #2: Compressed wood for bending ...
Thomas M Diel  Member
Website: http://thomasdiel.com
Elia
I can't answer your question but on a similar note there was a company in 2004-2005 showing at the IWF in Atlanta that was compression bending and shipping you the moisture packet plastic sheeting encased compressed wood to work & bend yourself. Anybody know their name and if they are still around? They were wrapping 8/4 in tight knots at the show, pretty intriguing?
I worked in the contract furniture field and we subbed out most all of our curved rails to Sawyer Bentwoods. Great people to work with.
Just remember your not just steaming, but also compressing; i.e. your collapsing / plasticizing the wood cell structure and essentually folding the cell walls over themselves and then freezing them back by drying and will only regain about 60-80% of the strength back respective of amount of bend & especially considering your tool handle scenario. Drying and post bend clamping / aging are crucial with regard to brittleness.
Speed does matter as the video shows too much handling time before its in the jig from my experience steaming, your on another level with adding compression.
Best of luck,
Tom
http://www.sawyerbentwood.com/
6/24/20       #3: Compressed wood for bending ...
Pure Timber is the source
http://www.puretimber.com
6/24/20       #4: Compressed wood for bending ...
My experience in pre-bending wood was a happy accident. I was steaming and bending 3 x 7/8" hickory into gentle curves of approximately 10-12" radius. As I loaded my blanks and tried to bend them I couldn't manage to pull them to the form fully so in a panic I threw one on the floor and stepped on it to straighten it to put back in the steam box.
Once I tried to bend it again it bent easily without even needing clamps to pull it down to the buck.
A little while later I read an article by Michael Fortune about the technique of pre-bending then free hand bending the other direction. Fine woodworking around 2006 or so. It seems that once the fibres have been freed from each other than the bending is much easier.
I haven't watched the video but I think the compression is done to eliminate tension failure so maybe you are applying too much compression.
6/24/20       #5: Compressed wood for bending ...
Okay so I watched the video. I do think the pre bending will help the process. You may be getting compression failure at the ends because the fibres have not been free to slip along the length which the pre-bend might be doing.
    • Anver Corporation
    • CP Adhesives
