Furniture Making
Subject: Re: How to make sure to player wooden compartment slides side to side well?
3/21/21
Alex Member
Hello,
I am designing kitchen drawer organisers. Some of them are going to be comprised of two levels, bottom-level main big compartments and a top-level with more shallow compartments. The top-level compartments are going to be half size of the drawer width so that I could push it left to right.
My goal is to make the top-level box very snug and slide smoothly. Kitchen is a busy place and you want to do things quickly and with your closed eyes, so I can't allow the box to get stuck or not wanting to slide when I need to access the bottom-level.
Could someone advise me on how to make sure they slide smoothly?
Thank you
Alex
3/21/21       #2: How to make sure to player wooden c ...
Drew Z Member
You may have luck with a similar solution to this, turned perpendicularly:
https://www.svwoodcrafters.com/wp-content/uploads/2015/11/Stacked-Cutlery-02_slide
.png
Use a side mount drawer slide that is 1/2 the width of the drawer mounted to the front and back of the interior of the larger box. The top, shallower organizer can then be slid side to side with ease.
Another option: make the top organizer with the bottom overhanging on the front and back by ~3/8". Cut a corresponding groove in the larger drawer box to act as a track for the upper tray to slide in, with the overhanging bottom acting as the tongue. If the track is kept waxed it will function very well.
3/24/21       #3: How to make sure to player wooden c ...
rich c
Wood is not an inert material. It swells, shrinks, and moves from season to season. Making anything in wood really snug will likely result in it being stuck during high humidity seasons.
3/26/21       #4: How to make sure to player wooden c ...
BH Davis  Member
Perhaps the top box could be made slightly undersized for sliding and then apply an approx. 1/8" thick, slightly larger, plastic panel, say nylon or UHMW, to its bottom. That plastic will remain stable and slide easily.
