Furniture Making
Subject: Re: Knife hinge door
Knife hinge door
10/29/21
Does anyone know where I can get this type of knife hinge?
It is a side door to this table that has a flip down part to it and I need to make this door because the moving company lost the other one
10/29/21       #2: Knife hinge door ...
Kevin Jenness Member
It looks like a Youngdale hinge. Try Woodworker's Express.
10/30/21       #3: Knife hinge door ...
Kevin,
I agree, but I’m just use to seeing their cabinetry hinges on cabinetry doors. It looks a bit different than a cabinetry hinge
11/2/21       #4: Knife hinge door ...
D Brown
There are several different configurations of those hinges, let me know if you can't find any I have a bag of batch of them and would be happy to send you what you need. Good luck.
1/5/23       #6: Knife hinge door ...
Jipec Member
To find the right knife hinge for your table, you may need to measure the thickness of the door or panel and the distance from the edge to the pivot point. It would be best if you also considered the weight of the door or panel and the desired level of resistance when opening and closing it. In addition, you may want to consider contacting trained specialists locksmiths se20 for help.
I hope this information helps!
    • Anver Corporation
    • CP Adhesives
