Furniture Making
Subject: Re: Using Pith in Teak Table LEGS
8/29/23
Derek Member
I know it generally is advisable to remove the pith out of most species when making furniture to avoid cracking due to moisture movement.
I have a project where I will be using Teak for 4 table legs and am considering leaving the pith in the center for the legs. I know there are species less susceptible to cracking at the pith and I understand that teak is a very stable wood. Has anyone had substantial experience with teak to advise me to take the extra time to saw the pith out and relaminate the legs or am I overthinking process?
Thanks for the advice.
8/30/23       #2: Using Pith in Teak Table LEGS ...
All teak is not the same. Plantation teak has huge growth rings in comparison to natural teak trees. Pith cracking is from drying shrinkage, if that is what you mean by "moisture movement". If you are referring to seasonal wood movement, that's a different story. If you look at wood shrinkage charts, Teak is not much different than Western Red Cedar, so I wouldn't rate it as very stable. I've seen a lot of cracked pith WRC.
Radial % Tangential %
Teak 2.5 5.8
WRC 3.1 5.0
9/1/23       #3: Using Pith in Teak Table LEGS ...
Keith Newton
Besides the normal checking issues of leaving the pith in any structural element like a leg, you should know that Juvenal wood isn't as strong as that farther out from the pith. It tends to be brash, meaning only a little bend before it breaks catastrophically. If you choose to go ahead, at least when you get the parts roughed out, take them in hand and whack them over something to see if they break before you get too far along with a lot of labor added to the parts.
9/2/23       #4: Using Pith in Teak Table LEGS ...
Derek Member
Thanks for the tips. I have decided just to remove the pith and laminate boards to the size I need.
    • Anver Corporation
    • CP Adhesives
