Furniture Making
Subject: Re: Dark Burl Banquette and Table
2/15/24
vince Member
A client asked for a quote to build something similar to the attached photo in a dark "espresso" stained burl wood.Legs. Photo also attached of the finish/figure she is after.
Am I best off planning this as veneer over mdf? I have done a little veneer work, but never built curved furniture legs.
Is solid lumber an option?
What species would be best in your opinion?
View higher quality, full size image (500 X 717)
2/15/24       #3: Dark Burl Banquette and Table ...
vince Member
2/16/24       #4: Dark Burl Banquette and Table ...
I don't see any curved legs.
2/16/24       #5: Dark Burl Banquette and Table ...
vince Member
Apologies. Curved bench end.
2/17/24       #6: Dark Burl Banquette and Table ...
Pete
I would tell the client to veneer the table top in burl and do the banquet seat in solid walnut. Veneer the top on whatever core you want with a solid wood edge. If they want everything in burl, its doable but time consuming so charge accordingly. If they want everything in burl, veneer it on a stable solid wood.
2/17/24       #7: Dark Burl Banquette and Table ...
vince Member
Thank you Pete!
Exactly the support I needed.
2/20/24       #8: Dark Burl Banquette and Table ...
chris
if you are going to veneer top i would use mdf and make sure you balance the panel crossplying each side so you use 4 sheets of veneer. 2 on each side.
And solid wood for bench.
2/20/24       #9: Dark Burl Banquette and Table ...
vince Member
Chris:
Do you mean a lesser grade of veneer running crossways under the walnut burl veneer?
If so, what type of veneer for the one under the burl?
Also, I assume I can use cheaper veneers like oak to balance on the bottom of the table top?
2/21/24       #10: Dark Burl Banquette and Table ...
chris
yes. we currently use sapele. it is a nice closed grain wood and not too expensive.
I would use that on both sides or something similar.
3/28/24       #11: Dark Burl Banquette and Table ...
Erick Member
Yeah sapele is great for its excellent stability, durability and super cozy reddish-brown color
5/30/24       #12: Dark Burl Banquette and Table ...
David William  Member
For curved legs and an espresso-stained burl wood finish, veneer over MDF is your best bet for stability and achieving the desired look. Solid lumber might be challenging for curves. Consider walnut or maple for the species, then stain accordingly.
1/28/25       #13: Dark Burl Banquette and Table ...
Veneer over MDF is a great option for achieving a smooth, consistent finish, especially with intricate curves. For the legs, solid lumber could work, but keep in mind the difficulty of bending it. I'd recommend using a dense hardwood like walnut or cherry, as these species have rich grain and can take a dark "espresso" stain well.
