Furniture Making
Subject: Re: White Cedar for furniture making
8/5/24
Sean Hayden Member
Hey fellow forum readers,
I was discouraged from using White Cedar for a furniture desk bc it is not compatible with the planers, joiners, rip saws &c. too soft and there is resin. Is this true? This is the same wood that cabin log furniture is made from but I want to make nicer pieces of furniture with White Cedar.
Can this be done if the lumber is dried properly? What about Pine? Would this type of soft wood damage machines?
Thank you,
Sean
8/11/24       #2: White Cedar for furniture making ...
Dave Sochar Member
The stuff is barely wood. Extremely soft.
It was used for cabins and furnishings because it was logged to build the cabin, not because anyone desired the stuff, sought it out and brought it in to the cabin sites.
I think that today, it is used mostly for the Adirondack chairs you see everywhere.
8/13/24       #3: White Cedar for furniture making ...
duster
I've made some nice pieces using clear western red cedar and alaska yellow cedar. White cedar is just too soft for anything that is expected to last more than 2 or 3 years. I've also made a lot of pine pieces, usually with furniture grade white pine. It's soft and dents easily, so it's not great for dining tables, desks, coffee tables, ect. I have made dozens of bedroom pieces with pine and it's held up fairly well. As far as damaging machinery, I don't think that's really an issue except pine can gum up saw blades, planer and joiner knives, router bits and sanding belts.
View higher quality, full size image (800 X 940)
View higher quality, full size image (672 X 340)
9/21/24       #5: White Cedar for furniture making ...
Olmo9 Member
What specific characteristics of western red cedar and Alaska yellow cedar make them preferable choices for durable furniture compared to white cedar and pine?
11/1/24       #6: White Cedar for furniture making ...
Paisley Peacock Home Member
Hey everyone,
I wanted to weigh in on the discussion about using White Cedar for furniture, particularly for a desk. While it's true that White Cedar is softer and contains resin, it can still be used for furniture if you're careful and take some precautions.
View higher quality, full size image (690 X 410)
11/1/24       #7: White Cedar for furniture making ...
duster
WTF? I thought this was a woodworking forum, not an online retail site.
11/1/24       #8: White Cedar for furniture making ...
Dave Sochar Member
Retailers often are drunk on getting the name out. But I agree with Duster - this is no place for selling. If so, I would mention my book - Small Shop Production .......
Cedar furniture? I can imagine that bed after a few months, squeaking every time anyone moves, the bed rocking, and denting and splintering as vacuum hits it, etc.
Remember, just because you can does not mean you should.
4/24/25       #9: White Cedar for furniture making ...
Daiva Member
None of the common pines “damage” machines either. Southern yellow pine is harder, heavier, and can tax smaller lunch&#8209;box planers simply because you’re feeding denser material, but normal knives handle it.
4/28/25       #10: White Cedar for furniture making ...
David William  Member
White Cedar can be used for furniture, but it’s true that its softness and resin content may cause issues with some tools like planers and saws, especially if not dried properly. It’s best to ensure the wood is thoroughly dried to minimize resin and avoid clogging machines. Pine is a similar softwood that works well for furniture but also requires careful handling. Both can be used with the right preparation, though you may need to clean tools more often.
