Furniture Making
Subject: Re: Entry Door Panel Thickness
11/12/18
Derek Member
I am currently making an entry door for my home from Oak. I have milled all the rails and stiles to 1.75" thick and I now will begin to make the doors raised panels. I will be using a raised panel bit with my router table to create the panels for the door. My question is at what thickness should my panels be?
I have both 4/4 and 8/4 rough material. I would like to use the 4/4 material for the panels however I am thinking this will be way to thin for the door.
I was wondering if I milled two panels to 7/8 thickness and created my raised profile so that the tounge on the panel was 1/4 thick. Dado a 1/2 inch groove in the door and stack two raised panels back to back to fit in the 1/2 inch groove. Are there any reasons that I am not seeing as to why this might be a bad idea? My other option would be to laminate the two panels but I would like to bypass laminating if possible to save myself some time.
11/12/18       #2: Entry Door Panel Thickness ...
mike
I have made an entry door for myself 2 inches thick and came across the same problem so what i did was to make 2 panels and put them back to back as you described except i put a 3/8 sheet of insulation between them. The insulation was the type used for vinyl siding. Never had a problem with it.
11/14/18       #3: Entry Door Panel Thickness ...
John Member
You will be better off if you use two separate panels. They will be able to slide past each other with the different RH levels inside vs. outside and have less tendency to warp/crack than one, full thickness panel. You can make them any thickness you want, really, even thicker than 1-3/4" when combined if you want though I don't like the look. Mine are usually 1-1/4 to 1-3/8" combined thickness with a 1-3/4" door with a tongue 5/16 - 3/8" on the edge of the raised panels. But there are no absolute rules (or at least I'm unaware if there are) so if you want to use 7/8" panels go to it.
Be sure to finish the panels on all edges and both sides, too. I put a sheet of aluminum foil between the panels as a vapor barrier, but if you use a wider dado or thinner panels you could use closed cell foam instead for slightly better thermal performance.
John
12/7/18       #4: Entry Door Panel Thickness ...
I do similar to John but use a sheet of stiff plastic between.
12/10/18       #5: Entry Door Panel Thickness ...
Derek Member
Thanks. I will definitely go with two panels then. This will actually be made for a house in Panama. Fortunately there is not much of a temperature change year round. Just tends to be a bit more humid during rainy season.
12/10/18       #6: Entry Door Panel Thickness ...
Temperature doesn't have much affect on wood, moisture does. Direct sun can heat the wood and drive the moisture out. The affect takes place first on the outside surface resulting in that surface trying to become concave. If enough force is generated, it will crack. I'm guessing that thinner panels are more likely to have less differential than thick ones. But they would also be weaker. Choose a moisture level in the lumber that will be at equilibrium with it's use location.
4/6/19       #7: Entry Door Panel Thickness ...
Jean Member
two panels options is great.
1/30/26       #9: Entry Door Panel Thickness ...
Seven Member
Website: https://www.zonledoors.com/
Furniture and door coordination is such a key detail for cohesive interior design! Matching the wood grain and finish of your cabinetry with your entry doors can elevate the whole space’s vibe. These solid wood door and furniture style matching tips share how to pick complementary tones without clashing.
