Furniture Making
Subject: Re: Can I use carpenters glue on my MDF shelves?
8/31/22
Eric
I purchased a bunch of pre made shelf boards for a wall mounted storage cubbie project. I'm using three 6ftx1ft boards and six 2ft by 1ft boards using the small ones as the vertical component. I have notched these into the middle shelf and will use screws through the upper and lower shelves.
Will carpenters glue work well on the laminated/veneered surfaces? The notches are fairly snug even dry but there are a few with a 16th gap in places.
I also have "PL" construction adhesive that I considered using but the advise is that wood glue is superior on bare MDF.
9/1/22       #3: Can I use carpenters glue on my MDF ...
snugthejoiner
5/8/23       #4: Can I use carpenters glue on my MDF ...
Smith Martin  Member
Website: myduckling.com.au/
Yes, carpenter's glue can be used on MDF shelves. However, since the shelves are laminated or veneered, it may not adhere as strongly as it would on bare MDF. The snug notches may help hold the shelves together, but any gaps could potentially weaken the structure over time.
If you have concerns about the strength of the carpenter's glue, you could consider using the PL construction adhesive as a supplement. However, it's important to note that the manufacturer's recommendation is to use wood glue on bare MDF.
Ultimately, the decision on which adhesive to use will depend on your personal preferences and the specific details of your project. It may be helpful to do a small test with both types of adhesive on a scrap piece of MDF to see which one provides the strongest bond.
2/19/26       #5: Can I use carpenters glue on my MDF ...
Steve Markovick
Ad budgets can disappear fast if you’re not watching where clicks actually come from. Even solid woodworking shops running online campaigns can get hit by fake traffic without realizing it. I recently read about ad fraud threats in 2025, and it really highlights how important proper tracking and verification tools are. Protecting ad spend is just smart business management.
