Furniture Making
lubrication for extending dining table sliders
1/30/17
Graham Clarke Member
Hello all. I am preparing product care sheets for extending dining tables that we are launching for the first time. If the user finds that over a period of time the sliders require lubrication, what type of lubrication should be used? (I was thinking something along the lines of silicon spray as opposed to oil, as oil might drip down onto the the users clothing...but maybe the silicon spray will not be compatible with the lubricating grease already used inside the slider). Any suggestions for compatible lubrication products are welcome. thank you!
1/30/17       #2: lubrication for extending dining ta ...
Robert Member
How about using a wax candle. Cheap to use and wont drip ( unless you light it of course )
1/30/17       #3: lubrication for extending dining ta ...
D Brown
Are the table slides made of wood parts ?
1/30/17       #4: lubrication for extending dining ta ...
Yeah, what kind of slides are we talking about. I would never recommend silicone to be used anywhere around furniture. I pity the refinisher that has to do that table some day. It will be fish eye heaven!
1/31/17       #5: lubrication for extending dining ta ...
my apologies. I should have said that its a metal sliders with what appears to be small ball bearings on the inside of the slider... Yes, I agree about the silicon spray too should the table be repolished at some point in the future. Personally I think the grease inside the sliders will last at least half a life time! but the company I work for wants me to make a customer care sheet (this is for mass production order), and the sheet will advise the end user that 'some lubrication of the slider may be required over a longer period of use'. SO I just need to guide the end user towards the correct lubrication product. Thanks again for the reply post and any other suggestions.
2/2/17       #6: lubrication for extending dining ta ...
I would list a few drops of sewing machine oil. Its readily available at any hardware store. It's actually the correct lubricant to renew grease.
The fact that its thin and runny will limit how much they use. The worst thing about spray lubricants is they go everywhere.
I would also mention a ban on WD-40 and silicone sprays. I have seen these on products that actually need maintenance.
2/2/17       #7: lubrication for extending dining ta ...
I'd suggest that a greased metal slide would never need maintenance. I open mine twice a year, Thanksgiving and Christmas.
