Furniture Making
Rocking Chair Help
6/6/18
Jon Member
I'm building my first rocker, it's just for me. I need to know what the optimal angle arc for the actual rockers. Distance from the fastener points is 24" Any help that be provide me would be greatly appreciated, as this is a one off project. Just can't seem to get the angle right.
6/6/18       #2: Rocking Chair Help ...
Bruce H
Try looking in the back issues of Fine Woodworking.
6/6/18       #3: Rocking Chair Help ...
Antique store is the best design studio I've found for rockers. Find a junker that is comfortable, buy it, and you have all the dimensions you need. I've never measured one, so can't help with numbers.
6/7/18       #4: Rocking Chair Help ...
Dave Nauman  Member
Website: http://www.dcnchair.com
I use a 37" radius for my rockers.
View higher quality, full size image (679 X 960)
6/7/18       #5: Rocking Chair Help ...
Matt Calnen
David, nice chair. Can you recommend a book or site that could help me with a nice rush seat like yours? Thanks
6/8/18       #6: Rocking Chair Help ...
Dave Nauman  Member
Click on the link below -
Video
4/19/22       #7: Rocking Chair Help ...
Phil324  Member
Website: https://www.portaloutdoors.com/
Check this https://www.portaloutdoors.com/products/big-boy-rocker-chair
8/14/23       #9: Rocking Chair Help ...
Laura Member
The optimal angle for the arc of the rockers in a rocking chair depends on several factors, including your personal comfort, the rocking chair design, and intended use. However, a common angle that's often considered comfortable for rocking chairs is around 12-15 degrees.
To calculate the arc angle, you can use trigonometry. The tangent of the angle is equal to the rise (height difference between the fastener points) divided by the run (distance between the fastener points).
Here's how you can calculate it:
Tangent (angle) = Rise / Run Angle = arctan(Rise / Run)
Given that the distance between the fastener points (Run) is 24 inches, you can adjust the rise to achieve the desired angle. For example, for a 12-degree angle:
Angle = arctan(Rise / 24) 12 degrees = arctan(Rise / 24) Rise = 24 * tan(12 degrees) Rise ≈ 5.07 inches
This means the difference in height between the fastener points should be approximately 5.07 inches to achieve a 12-degree rocking arc.
Remember, these calculations provide a starting point, and you should also consider factors like the chair's design, your body's comfort, and personal preference. You might want to create a mock-up or prototype to test the angle before finalizing your design. Click here for further guidance, you will get more info!
1/30/24       #12: Rocking Chair Help ...
harbin Member
The optimal angle arc for the rockers of your rocker chair can be determined by considering a few factors. One important factor is the desired rocking motion and comfort level you want to achieve. Generally, a moderate angle arc of around 10 to 12 degrees is commonly used for rocker chairs, providing a comfortable and smooth rocking experience. However, personal preference and body dimensions can also play a role in determining the optimal angle arc. It is recommended to test different angles using a prototype or mock-up before finalizing the design. This will allow you to adjust the angle to your liking and ensure a comfortable rocking motion.
    • Anver Corporation
    • CP Adhesives
