Furniture Making
Adjustable pilot drill press bits
6/13/20
Glenn W Healy Member
I’ve been in woodworking for 50 years, I worked many of my early years in the furniture manufacturing industry at a number of different shops, the one thing they all had in common was the an adjustable pilot and countersink bits they used on their drill press. It basically looks like a Kreg bit, but with a movable pilot running through its center. If anyone out there knows what I’m talking about, or better yet, knows where I could find one, I would really appreciate it.
6/13/20       #2: Adjustable pilot drill press bits ...
If Im thinking of what your thinking Amana sells them.
Amana Tool Face Frame Counterbore Drill
6/13/20       #3: Adjustable pilot drill press bits ...
Or perhaps these:
Amana Tool Shankless Counterbore Bits
6/13/20       #4: Adjustable pilot drill press bits ...
Jim Acconcio
Website: http://designerclosets.com
The drills are made by W.L. Fuller They are made in RI.
W.L. Fuller Drill Stops
6/13/20       #5: Adjustable pilot drill press bits ...
TonyF
Glenn Healy:
As Jim Acconcio points out, these were made by Fuller, and are still available, even as made by other manufacturers. 30 years ago I was gifted a set of these in a mahogany box (hate to think what that costs now)
The ones I have came with tapered twist drill bits, so if you need them for the old style wood screws, that would be what you want. I replaced those with straight twist bits, which work better for drywall screws and other straight shank screws.
The Fuller set had plug cutters that made plugs to fit the deeper counterbore, but if all you need is the straight bits with a tapered counterbore to accommodate the screw head, you might see about the set in the link.
Hope this helps.
TonyF
Amana Countersink set
6/15/20       #6: Adjustable pilot drill press bits ...
I personally cant stand the drill/counterbores/countersinks that set-screw onto the flutes of a standard or taper drill. They grip horribly (set screw), they jam/pack up miserably as well. Even the Fullers, which are great, are not so great.
When he said "Kreg bit" I didnt think of anything with regards to a drill/countersink or a simple stop collar on a drill bit.
Assumed he was looking for a piloted flat bottomed hole similar to what a Kreg bit drills but allowing you to set the pilot drill depth.
We run the adjustable face frame bits from Amana in a couple operations that allow for a clean 3/8" bore for a plug and we can set the pilot depth as needed (not possible with a Kreg bit). The fuller counterbores work for a 3/8" plug but again having to set screw on the flutes kinda stinks.
6/15/20       #7: Adjustable pilot drill press bits ...
Jim Acconcio
Fuller Page 29 Countersinks · Counterbores · · Adjustable Countersinks and Counterbores for deep hole drilling made of High Carbon Steel All sizes are 4-1/2” overall, 2-1/2” of twist, 1/2” split shank, and has one set screw.
This countersink has a Adjustable center drill
6/15/20       #8: Adjustable pilot drill press bits ...
My page 29 shows a 5C option which is phenomenal for that counterbore provided you have 5C and a controlled feed where the feed cant be taken away from you. I have some piloted auger style counterbores but no different than a piloted electricians auger, hand feeding, they can just burry themselves into the work if they are not controlled feed or fed with a stop.
