Furniture Making
Cut Top/Bottom Angle on Tapered Legs
10/28/20
howard
Website: http://woodcontours.net
I have round tapered legs that I need to cut a 3 degree angle at the top and bottom. Any suggestions on how to secure them to cut the angles? Thanks
10/28/20       #2: Cut Top/Bottom Angle on Tapered Leg ...
Rocket
Make clamping collars by drilling the leg diameter in the center of a square or rectangular block then cut the blocks in half and secure around the legs with screws on the outside edges of collars or affix the blocks to a "sled" (ply/mdf base) and mount a destaco clamp in a way to hold the collar against the leg. Once the legs are secured in the collars you can cut the angle on a chop saw or miter gauge on the table saw. The collars would be similar to a metal shaft collar.
If the leg diameters are unusual sizes bore a slightly oversized hole and use a shimming material like a thin piece of rubber inside the collar that will contour and grip the round edge without damaging the surface.
10/29/20       #3: Cut Top/Bottom Angle on Tapered Leg ...
howard
Thanks for the help I made the half circle cutouts that you suggested and it worked great.
