Furniture Making
Solid wood steps
12/5/21
Lu Member
I'm planning to glue up, face to face alternating grain direction. What would be a good way of making a stable , strong glue up of that volume.
Thanks,
Lue
12/5/21       #2: Solid wood steps ...
I assume you have been looking at Cross Laminated Timber structures and want to do your stairs that way. If you are to have any success in reproducing what is done with massive presses and production lines you will have to start with carefully dried and dressed stock. Your laminations will have to be extremely flat because you will not be able to achieve the even clamping forces necessary to flatten out any warp in the large surfaces without a hydraulic press.
You cannot introduce any moisture to the glue line so polyurethane or epoxy is what I would choose.
Have you contacted a CLT manufacturer about purchasing a blank or finished product?
12/6/21       #3: Solid wood steps ...
You would likely get better responses posting in the architectural forum. Steps are seldomly considered furniture.
1/24/22       #4: Solid wood steps ...
West Hollywood Pressure Washing
Website: https://westhollywoodpressurewashing.com/
2/21/22       #5: Solid wood steps ...
correy Member
HI, It's not an ideal method for the small shop as a poster already said... BUT I did do steps for a commercial job that nneded a quick turn around in the same manner. The challenge is to get pressure to the center of the laminate. So you either have lots of deep reach clamps or invent something. I made solid oak cauls about 1.25" thick with a strong back on each caul. I only screwed the ends of the cauls and strong backs, no screw in the middle joining them. In the strong back, I had made a slot to drive a wedge so that it would flex the center tighter. I had clamps on each end of the cauls of course. Depending on the thickness of your laminates you may need to have cauls very close together. With two pieces 1.25 thick, making 12" deep treads, 6" was max I could space the cauls, and probably 4 to 5 inches apart would've been Ideal. It took about 50 clamps for a 10' tread if I remember. Lots of fast work. Staves would have been much better. Wasn't my design or material, just a quick job in and out. Much more practice to just buy the correct thickness of lumber.
4/16/22       #6: Solid wood steps ...
vicent
Website: https://eventosbcn.com/
Great information! Thanks for sharing us!
