Furniture Making
glass door solutions?
2/26/13
Ethan Member
I'm working on a large piece (display case) which will have 2 glass doors approximately 48"h x 42"w. I'm planning on 1/4" glass, but am wondering if anyone has preferences for either hinge or sliding track hardware.
I've not used glass doors of this size before, and would appreciate any advice - at this point I could go either way in terms of how the doors operate. I've got a call in to Hafele to see what they've got - the catalog I have does not show any sliding hardware suitable for doors of this size.
thanks
2/27/13       #2: glass door solutions? ...
Rick W
Try C.R. Laurence-
http://crlaurence.com
2/28/13       #3: glass door solutions? ...
mark
Fancy hardware notwithstanding, it's hard to beat tempered glass with pencil polished edges that slide in a wood groove. Call me old fashioned, but most of the time simple is better. A 1-1/4" polished hole is a good pull, and low-iron glass has a nice blue edge. Use the materials; don't buy stuff you don't need.
2/28/13       #4: glass door solutions? ...
Ethan Member
thanks. in general i agree, Mark, but in this case if the glass were in grooves and it broke, it would be impossible to replace. unless the groove was added as an additional applied wood runner, which may be a possibility. in general though, im leaning towards hinges for their ease of use...
2/28/13       #5: glass door solutions? ...
mark
I'll have to take your word on the impossibility, but if you make the top groove a little deeper it might open up some other options to you.
3/1/13       #6: glass door solutions? ...
ThomasFR
Sliding doors of all materials are routinely installed & removable via the top groove being deep enough to slip them up into said groove(s) & lowered into the lower grooves. Each 1/4" door is 48" x 42"? If hinged, cabinet wants some real mass, or to be secured to floor or wall. Regarding breakage, tempered glass might be considered for liability issues. Good luck.
3/1/13       #7: glass door solutions? ...
Ethan Member
Thanks, I think you're right. I was over thinking things a bit, and telling myself I needed something fancy. A groove for the doors it is.
I had hoped for tempered, but I think it may be out of the budget for this project.
Ethan
4/29/13       #8: glass door solutions? ...
Joe Romero Member
I think you can use fiber doors as well if you want as we are into this business for 30 years and can assure you that your clients will like this product as well. Try to get their opinion or from other client next time, I hope it will be easier for you and better for your client.
7/20/16       #9: glass door solutions? ...
Ryan Richards Member
Website: http://caldwells.com/interior-doors/glass-doors
I have shared the page above, it is actually the same source where I got out entry glass door.. the good thing with it, is that it is made of fiberglass door with the unique thickness. You can even request your own design or size according to you door frame size.
2/22/22       #10: glass door solutions? ...
Daniel North Member
It would be impossible to replace. unless the groove was added as an additional applied wood runner, which may be a possibility.
