Furniture Making
Maple Banquette Seating
1/31/24
Nicholas Crobaugh Member
Hey all,
Looking for a little advice here on which method would work best.
I've got a banquette bench seat I'm looking to make from find of some T&G 5/4 hard maple gymnasium flooring. Question I have is whether to glue this up as 2 blanks for the seat and back, or nail it in place on plywood much like a traditional flooring install.
Total length is around 155" right now +/-. I have the panel clamps to be able to get this properly glued but only have the ability to plane 12" widths and I'm making the seat and back 18". I can glue it into 4 sections that I'll join after cleanup and only need to deal with the single seam by hand. My first test I glued up has stayed very flat ( even in FL humidity swings ). However, I may be overcomplicating this and possibly better off just tongue nailing them board by board after I resurface them.
Any opinions are greaty appreciated.
All the best,
Nick
View higher quality, full size image (721 X 1000)
2/7/24       #2: Maple Banquette Seating ...
I would glue it up myself. But the T&G of flooring isn't symmetrical and will likely not glue up flat You might have to cut off the tongue and joint the two edges to make a decent glue surface.
In your picture it does look like the T&G are glue-able which would be unusual for a T&G flooring system which is designed to look tight on the top and leave an opening on the bottom so things can be nailed tight.
With gluing the boards won't separate, with nailing they will move around with the seasons.
2/15/24       #3: Maple Banquette Seating ...
sosoffice
Website: https://www.sosoffice.in/
It seems like you're planning to create a banquette bench seat using T&G hard maple gymnasium flooring. You're considering whether to glue the pieces together in sections or nail them onto plywood like traditional flooring.
Gluing the pieces together seems like a good option, although the T&G flooring might not be perfectly symmetrical for gluing. You may need to remove the tongue and groove to ensure a flat surface for gluing.
Nailing the pieces could lead to movement with the seasons, whereas gluing should keep the boards stable.
In my opinion, gluing the pieces together, even in sections, would provide a more stable and durable result for your banquette bench seat. However, you may need to address the asymmetry of the T&G flooring for a successful glue-up.
    • Anver Corporation
    • CP Adhesives
