Furniture Making
Pinning Raised Panels
4/21/24
howard
Website: http://woodcontours.net
I've heard that some people use a 23 gauge pin in the center of the top and bottom of a raised panel to make sure it expands evenly across the width. I've not done this, what approach are you using? Thanks
4/27/24       #2: Pinning Raised Panels ...
Generally that's what I do. With some larger panels I put 2 pins in each end grain separated by 2 inches or so. Close enough that expansion would move them around.
5/31/24       #3: Pinning Raised Panels ...
BH Davis  Member
Pins work as do "space balls" rubber bead sized spacers.
8/28/25       #4: Pinning Raised Panels ...
H LC Member
Website: http://www.hlc-metalparts.com/
Some people do use a 23-gauge needle to limit the panel's movement, but I personally prefer to leave a little slack in the mortise and tenon to allow the panel to expand and contract freely. This prevents bulging and keeps the seam even.
