Furniture Making
Mortise & tenon tolerance on bar stool legs — how tight is too tight?
11/25/26
Dawn Feng
Website: https://furniture-wholesale.com/
Hi all,
Longtime lurker, first post here. We build frame furniture in Guangzhou — bar stools, side tables, that sort of thing — so the mortise-and-tenon is the joint we bet the whole product on. Lately I've been second-guessing our fit tolerances and wanted to hear what other shops hold.
Our current spec, on a 20 mm leg tenon cut on a CNC router:
- Cheeks at +0.10/+0.15 mm interference against the mortise walls
- Shoulders machined flat and square in the same setup, no hand shimming
- Tenon edges chamfered about 1 mm so glue doesn't scrape off during assembly
- Dry fit on every joint before glue — no exceptions
Where it gets messy for us is moisture. Kiln-dried stock comes in at 8-10% MC, but shop-floor humidity here swings hard between seasons. We've had stools that left the line piano-tight and arrived at the customer with visible shoulder gaps. Holding parts in the assembly room for 48 hours before gluing helped, but I suspect the real answer is sizing tenons after the wood equalizes, not cutting everything to final dimension up front.
The failure we see most isn't joints pulling apart — it's cheeks splitting because someone forced an overly tight fit and starved the glue line. I've started telling the bench that "squeaky tight" is worse than "snug."
Two questions for the folks doing this daily:
1. What interference do you actually hold on a 20 mm hardwood tenon?
2. Do you cut tenons to final size, or leave them proud and size after moisture equalization?
Also curious whether anyone cuts wedged through-tenons as a visible design feature on stools — we're playing with it on a new model and the glue-up logistics are trickier than they look.
Thanks in advance.
11/25/26       #2: Mortise & tenon tolerance on ba ...
I don't think you should be aiming for any interference. I aim for size on size which means the joint with applied glue slides together without a mallet blow.
According to Bruce Hoadley in his book Understanding Wood, the ideal joint has a .003" or approx .07 mm. I can't bring myself to machine such a loose fit though.
The book is a great reference for wood science. It was published by Taunton Press.
11/26/26       #3: Mortise & tenon tolerance on ba ...
nickko
I heard Norm once say "not so tight that you have to hit it in with a mallet and not so loose that you can hit it in with your hat"
