Subject: Re: fold down countertop
2/14/13
tom keifer
ive been asked to build a fold down set of countertops, 1 about 36" long, the other about 84" long, these tops are on either side of a stationary sink base. these tops are being made from solid walnut, 4/4 with the look of 5/4. My question is, has anyone done this here? Im torn on how to hinge it and attach it to wall. im looking at some shelf support hinges that look like they would work, the only thing that worries me is that the largest one is only 15.75" deep. leaving me just shy of 10" of unsupported c top. The other way i was thinking was putting a 2" wide "ledge" on wall and putting a series of piano type hinges along the countertop, upside down , so it folds inward. i would then make some mitered boards to prop up top against base molding at bottom and underneath front of c top ( which i have a 2" strip glued to give look of 5/4, cut from the same board and just flipped under. any thoughts??
2/15/13       #2: fold down countertop ...
mark
Make it like a gate-leg table; you can use panels for the gate-legs, and since they're attached to the wall, they don't even need to be legs. Fold up or down could work. If folding up, hinge a couple of inches off the wall, so gravity works with you to keep it up.
2/19/13       #3: fold down countertop ...
Rich
I did one with fold down legs on the front, piano hinge in the back, and spaced out so it sat flat to the wall. Wall mounted panels like Mark described would require them to get on their hands and knees, with the countertop held up, to access the panels. That 7' countertop is going to be very heavy and cumbersome to lift and work with. Caution the customer on the weight they will be dealing with since they have to bend way over to start lifting it. The front edge is only going to be a foot off the floor if it is a standard width top. It might make sense to make that two pieces. I used these brackets for the legs since the locked up and down positions. Not elegant for sure, but worked great.
Folding Leg Bracket
