Subject: Re: carbide inserts for a planer
6/17/13
Michel
Hi,
I'm wondering if someone can help me not spend 900 $ on carbide inserts on a King 20" hel. head planer ? I do a lot of exotic woods and went around the knives. I'm ready to change for 15 X 15 X 2.5 X 92 inserts but King is asking 89 $/box of 10.
6/17/13       #2: carbide inserts for a planer ...
Michel,
We can help you with that. Our list price is lower. You can give us a call @ 877-465-7012 or check our web site for a list of distributors.
6/19/13       #3: carbide inserts for a planer ...
Russ
Website: http://www.mirror-reflections.com
I might be able to help you $2.61 each
Go to our website above, Mirror Reflection's tooling catalog, under tooling and supplies, page 20, all kinds of sizes with prices listed for each size. Contact us page if we may be of assistance. Must purchase in boxes of 10.
Good Luck
6/19/13       #4: carbide inserts for a planer ...
Check with European tooling systems. They stock lots of inserts.
6/24/13       #5: carbide inserts for a planer ...
Try Great Lakes tooling their price is a third of that.
800.873.4528
8/4/13       #6: carbide inserts for a planer ...
JIMMY RUSTLE
I do not like or recommend carbide inserts because to my knowledge you cannot sharpen them. I like my high speed steel knives because I can sharpen them. It does not take long, and if your good at changing them it is FAST.
$900.00 Would buy ALOT OF HSS KNIVES.
11/18/13       #7: carbide inserts for a planer ...
hewhoworkswood Member
Website: http://saugahatcheewoodworks.biz
I just got some from Global Tooling for $1.73@.
global tooling website
11/19/13       #8: carbide inserts for a planer ...
Dan cook
I have seen these type planer heads advertised but have not seen them in use. Do they plane as smooth as high speed steel? Are they worth the money and who has one that is reasonably priced?
11/19/13       #9: carbide inserts for a planer ...
They do not plane as smooth as HHS but one pass through a wide belt fixes that. We have a 24" SCM that is very good. The inserts last forever, it is almost silent. There is virtually no tearout. Crazy grain goes right though no problem. Remember also that the inserts are 4 sided.
11/19/13       #10: carbide inserts for a planer ...
Dan Cook
I have an old 16" Powermatic. Where could I get a head for it that would be reasonable? Most of the ones that I have seen are for different sizes than 16".
11/19/13       #11: carbide inserts for a planer ...
Russ
Try this link below
Hermance
11/19/13       #12: carbide inserts for a planer ...
Try Byrd tooling
Byrd
11/19/13       #13: carbide inserts for a planer ...
When you are looking @ inserts remember that there are square cornered ones and eased corner ones. The eased corner ones produce a better looking surface. As for the idea that sharpening HHS steel is better, depends on how you value your time. We have a spiral inserted head on the first bottom of our molder. Easily runs over 100,000' before time to turn inserts. Can turn 3 times (4 sides) before buying new ones.
