Subject: Re: Floating cabinets in steel stud walls
9/26/14
Joseph D. Christman  Member
Website: IntegrityDesignBuild.com
I typically install in high-end residential projects, and was just asked to estimate an Italian cabinet installation in a high rise with steel stud construction.
They've installed 16ga strapping under the drywall already.
What methods do you guys like to use when attaching floating vanities, etc, to this wall system?
9/27/14       #2: Floating cabinets in steel stud wal ...
james mcgrew Member
We commonly install on steel strap in commercial, We use a self tap #8 counter sunk with a plam or fast cap, if it is high end and the backs are front of the nailers you may want to consider a french cleat with Zipits in the sheetrock as well
