Subject: Re: stud finder
stud finder
3/10/16
Fabian Member
Looking for some advice on a stud finder. I have went though 4 or 5 and have not found one that I feel does a good job at finding the studs everytime. I hate missing on an install. Can someone point me in the right direction. Which stud finder do you use?
3/10/16       #2: stud finder ...
Jarvis
See link below -
Link
3/10/16       #3: stud finder ...
I'm a huge fan of a bunch of rare earth magnets. Slide one around on the wall, and it sticks to nail or screw. Repeat. You can check with a tape measure, but easy to see the 16" centers. I've never had a failure or miss like I occasionally did with a purchased stud finder.
3/11/16       #4: stud finder ...
Jake
For wood framed walls I use a Franklin Sensors ProSensor 710. Only stud finder I have found that works well.
3/11/16       #5: stud finder ...
JM
Like you, we went through a bumch that never really worked very well.
We borrowed a homeowners once cause ours wasnt working.....we went and bought the same one the next day. This stud finder is simple, and to put it simply it just works.
http://www.leevalley.com/en/wood/page.aspx?p=69828&cat=1,43513
3/11/16       #6: stud finder ...
jimherron
I have the Franklin Sensors stud finder as well. Works at about 98%, much better than anything else I've tried. Fairly rugged as well.
Wet texture sends it it a tailspin. Dry it's on the money.
In close proximity to pipes I always double check with a pin punch just for insurance.
3/11/16       #7: stud finder ...
I like this one:
Magnetic Stud Finder
3/19/16       #8: stud finder ...
Bought the Franklin based on this thread.
Yes the Franklin is way better than the magnetic one.
3/20/16       #9: stud finder ...
Gerry
We bought the Franklin also but I still bring the old Zircon on the job when doing installs to do a quick scan for electrical wiring as the Franklin does not do that.
Gerry
3/22/16       #10: stud finder ...
Bernie
Really like the Franklin.
2/18/18       #11: stud finder ...
Andy Member
Franklin is the best that I have used. I have a box full of stud finders that do not work well.
Andy
2/19/18       #12: stud finder ...
Stu
Franklin, but the T6 instead of the 710. We had a number of failures with the 710, the microswitch failled in each of these cases.
