Subject: Re: How to fix 'bump's from pocket screws too deep
2/16/19
BPMore Member
Thanks in advance.
I built a AV cabinet as part of a project - a few 90 degree joints but not many! It's built like a trapezoid (so I don't want to tear it apart).
3/4" Rift Cut white oak
The back panel (same material) is pocket screwed (Kreg) to the sides -- a few pocket screws went too deep - when the cab is 'in the light' at a certain angle you can see these three bumps.
I'll back the screws out... but I doubt the bumps will go away -- how would you fix this.
2/16/19       #2: How to fix 'bump's from pocket scre ...
Mastercabman
Use a block of wood and tap them with hammer
It should go back to flat
