Subject: Re: Floating Shelf Butt Joints
8/7/19
Tom P Member
We have long runs (26') of 2 " thick floating shelves that we are planning to make in 8-foot sections. I am looking for recommended hardware to help draw the sections together during install. Hidden hardware preferably.
8/7/19       #2: Floating Shelf Butt Joints ...
MarkB Member
Lamello Invis may be an option if you really need something completely invisible
8/29/19       #3: Floating Shelf Butt Joints ...
Bill Member
Similar but different Clamex is much stronger and the only thing visible is a 4mm hole.
1/13/20       #4: Floating Shelf Butt Joints ...
Dan Dempsey Member
Website: CSaw.com
Hi Tom,
Lamello P-System would work well for you here. I'd suggest the Tenso P-14 for a completely invisible connection. This connector is used in conjunction with glue and no bar clamps are needed. As Bill mentioned, the Clamex is another option that's also part of the P-System and does not require glue. The trade-off with the Clamex is that there is a 4mm hole to access the cam lock mechanism. If you're able to hide that hole on the underside of the shelves then you'll be in great shape.
https://www.lamello.com/category/p-system-verbinder/
