Subject: Re: Floating Shelves
Floating Shelves
9/3/20
Gary
I was looking at a project this morning that calls for floating shelves in a commercial breakroom...on a tiled wall. I would plan on using something like the Hovr brackets, but wouldn't that run the risk of cracking the tile when we secure it to the wall??
What are other people doing in this application?
9/3/20       #2: Floating Shelves ...
Jared
I've used brackets from rightonbracket.com and they're very stout, but you'll need to open up the drywall and lag screw them to the sides of the studs. If metal studs, install blocking.
9/3/20       #3: Floating Shelves ...
kevin
The trick is to get in early, install your own blocking or if heavy gauge studs you might be ok... We have used this stacked plywood method in the past, the backside of the shelf has a mating pocket, which is then glued and clamped in position until dry, makes for a solid install, the shelf can also be slid on multiple times for scribing, some systems make no allowance for fitting.
View higher quality, full size image (750 X 1334)
9/5/20       #4: Floating Shelves ...
We did this by putting lag bolts into the studs and cutting the heads off and drilling holes into the shelves.
You can tap the bolts to get them level
I have heard that you can accomplish this with a single strip of ply screwed to the wall
See the link
Torsion box shelves
10/12/20       #5: Floating Shelves ...
Zach Gaddy
We use the drake bracket from Shelfology by mounting to studs and then once walls are up and tile in place slide the shelf over the bracket and silicone in place. Have used for several years and works great.
    • Cabinet Pro
    • Steve H. Wall Lumber Co.
    • WalzCraft
    • CP Adhesives
    • CabMaster Software
    • American Vision Cabinets
