Subject: Re: Drop down lid
Drop down lid
1/15/21
Vince schweiss Member
Doing a drop down desk lid.
Any suggestions on a "Stay" type to hold the lid level when open
Mdf material, 20" high X 40" wide
Flap type hinges
1/17/21       #3: Drop down lid ...
Vince,
The Pacta by Salice is a hardware system for drop down doors you may not have seen before. Pacta fits your requirements for the drop-down shelf to position flat and in-line with the bottom of the cabinet. Pacta is available with soft close or with Push to open features. There are several color options available for the decorative cover.
For a 40" wide unit, we recommend the use of a specially designed flap style hinge for added support.
Here is some information on Pacta. You can also download the full catalog from our web site.
Pacta is readily available from any Salice distributor.
Best of luck,
Dennis Bean
Salice America
View higher quality, full size image (1444 X 1888)
View higher quality, full size image (1424 X 1864)
Salice Pacta On Line
1/17/21       #4: Drop down lid ...
MarkB Member
Beyond Dennis' recommendations you might switch to a friction hinge instead of leaf hinges. I suppose you could mock up some other chest/lid hinges that are readily available.
1/18/21       #5: Drop down lid ...
Hi Mark,
There would be no need for friction hinges with Pacta.
All Pacta hinges are soft opening and give a gradual soft drop down of the door. The leaf type hinge shown is only necessary for doors over 40" and is recommended to support the center to prevent later warpage of the door.
The center hinge has a movement that is the same as the left and right Pacta hinges. This insures a perfect synchronization of all hinges.
Thanks & happy new year!
Dennis
1/19/21       #6: Drop down lid ...
Blum has a small stay for cabinet doors that operate vertically. HK-XS. Comes in three strengths and is adjustable so the door/lid will stay wherever you leave it. Or you can adjust it so it is slightly less than stable.
