Subject: Re: Overlay fillers
Overlay fillers
4/3/19
Phil Member
Hi ,
Just finished installing a fairly large kitchen with frameless cabinets. It was the first time I had to do "overlay" fillers everywhere (the face of the filler is flush with face of cabinet doors and the filler is undersized by an 1/4" to match the height of cabinet doors. Also the overlay fillers have an 1/8" roundover to match the edge profile of doors) . Cabinetry was all pre-finished
The way I went about attaching the fillers was as follows:
1) Cut squared edge filler same height as cabinet box.
2) Attached bumpers to back side of overlay filler then screwed from backside of box filler into overlay filler, being careful to not sink screws too much that they squished bumpers.
3) Scribed and attached to box by screwing through cabinet box box into box filler.
Is there a better way to do this? It was a bit of a struggle to get everything lined up nice.
Thanks for your time
4/4/19       #3: Overlay fillers ...
Jeff
I just screw a scrap piece of whatever flush to the face of the box anywhere we need a filler. After the boxes are hung I cut the scribe pieces and put them in place with thick double stick tape that matches the thickness of the bumpers.
4/5/19       #4: Overlay fillers ...
Bruce H
Keku brackets from Hefele work well fit this application.
4/9/19       #5: Overlay fillers ...
Is just leaving the fillers flush with the front of the cabinet a no no?
11/5/19       #6: Overlay fillers ...
Matt
Pat, having the fillers flush with the doors obviously is not a necessity but then again neither is crown, baseboard, door bumpers, soft close hinges, dovetail drawers, post cat finish, or any other number of things that can make someone's cabinets stand out from the rest.
It definitely looks better. Looks more properly thought through and "filled in".
Whether or not someone needs to go through the effort to do it isn't something I can answer, that's between the cabinetmaker and the client.
11/6/19       #7: Overlay fillers ...
pat s gilbert
Do you then miter them back at the bottom of the upper cabinets?
8/22/21       #8: Overlay fillers ...
troy miller
from some of my clients i get a 6" filler, rip and scribe, then with the drop pocket hole to the back of the filler and create a "L" shaped filler and hold it out to the 7/8' or....
    • CabMaster Software
    • Steve H. Wall Lumber Co.
    • WalzCraft
